run time menu in exe
 Hello all,
  I am facing a small problem regarding the run time menus.I created an exe with a custom run time menu.When i run that exe from the directory with which i created the exe,the run time menu is working perfectly.If i copy the entire folder to another location,the menu is absent.Can anybody please solve my problem?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 1 of 8
(3,472 Views)
is the rtm file also included when you copied the entire folder?
Regards
Guru (CLA)
Message 2 of 8
(3,471 Views)
Hi guru,
  Yes,rtm file is there when i copied the whole folder.
Srikrishna
Message 3 of 8
(3,458 Views)
Message 4 of 8
(3,450 Views)
hello all,
  Actually i created the run time menu only for a control....i am not using any llb.
thanks and regards,
srikrishna
Srikrishna
Message 5 of 8
(3,447 Views)
solved?
I tried to do the same but did not faced any problem (actually i included the rtm file in "always include" option while ceating the exe under source code and did not include the same in second attempt.. and both worked fine,,here is the attachment..BYW which version of LV are you using?
PS: Rename the .jpg to .exe
Guru
Regards
Guru (CLA)
Message 6 of 8
(3,439 Views)
hi guru,
  Thanks for your reply,but i am unable to view your code as my firewall is not allowing it.Could you zip it and attach?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 7 of 8
(3,429 Views)
Accepted by topic author srikrishnaNF
hello all,
  My problem is completely solved.I need to save the run time menu along with the control,so that you can get the menu over the control at different locations.For more details please  see this link...
http://forums.ni.com/ni/board/message?board.id=170&message.id=283588&query.id=1151684#M283588
http://forums.ni.com/ni/board/message?board.id=170&message.id=265916
Thanks and regards,
srikrishnaNF
Srikrishna
Message 8 of 8
(3,422 Views)
