run-time menu problem?
Can someone explain me what happens with run-time menus in my llb's after
Application Builder processing?
When I distribute my application in different directory, I can't see custom
run-time menu. At the same time my custom run-time menu operates normally at
directory where my llb was born.
(3,131 Views)
I believe that once you make the app using the app builder
the directory structure is one level deeper than in the development
environment.
If I am not mistaken, C:\labview\main.llb\main.vi becomes
C:\labview\main.exe\main.llb\main.vi
The same should apply to the run-time menus.
Kevin Kent
(3,131 Views)
To incorporate your runtime menus in a .exe make sure _NOT_ to save them
into the .llb
A quick fix is to open them from the VI and use 'save as' in the same dir
as the .llb
Save everything and build your app... custom menus are incorporated now.
The menu files are NOT saved with them...
Frank Lubbers
AIR Technical Automation
(3,131 Views)
