run-time menu with event structure
Hello everyone!!
I've tried to implement a run-time menu in my VI. I used 4 Boolean controls (run, stop, save, load) with corresponding actions in event structure. And I also wanted to trigger these actions with a run-time menu. I attempted to employ "Register for events", but it failed.
Is there any possibility to solve this out?Smiley Wink
With Thanks and regards,
Adam
(4,223 Views)
HI
Please find modified Main vi as attached.
Hope this helps
Regards
Santosh
(4,205 Views)
To handle a runtime menu you don't need to use register event. Use one of the Menu Selection events under <This VI>.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,203 Views)
Hi Adam,
As Mike said,  you don't need to use register event for handling  runtime menu.Check out the vi in this link.
http://forums.ni.com/ni/board/message?message.uid=853373#U853373
 Rgds,
Venky
(4,174 Views)
