runnin labview 2012 installer is asking for 2013 run-time engine
I'm running labview 2012 when I build a installer. I get an error. Some Installers you selected for this build are not available on this computer. The Installer is looking for NI Labview Run-Time Engine 2013
(3,195 Views)
What have you selected under "additional installers"?
(3,189 Views)
What happens if you de-select it and build the installer? Does your program install correctly?
(3,186 Views)
I selected to 2012 Run-Time Engine to be installed.
(3,182 Views)
Yes if I deselect 2012 Run-Time engine the build is fine. I never selected 2013 run-time engine to be installed. I'm running LV 2012
(3,177 Views)
did you download and install run ti,e Separately  that labview that you installed?!
(3,153 Views)
No the run-time was part of the LabView 2012 development suite. I did build before and had no problem.
(3,149 Views)
