running Lego Mindstorm with Labview 2019
Hi All,
I have Lego Mindstorms I use for a teaching Lab.
This year I have had to upgrade my PC's to Windows 10 so I installed LabView 2019 while I was at it.
Now however I realise the 2016 version of Labview is the last one supported for Lego.
When I log into my N.I. account I cannot download Labview 2016 version.
Did anyone else have this problem and if so how did you get around this issue or is there a link to download
the older version as the option is removed from my download profile.
thanks
Denis
Message 1 of 11
(5,169 Views)
Are you affiliated with a University or other academic institution?  Might they have an academic license you could use?  Have you tried calling NI and asking their advice in your situation?  I would hope they would be sympathetic to using LabVIEW as a teaching tool ...  You might also try calling the Lego/Mindstorm people.
Bob Schor
Message 2 of 11
(5,140 Views)
I would call NI, because if you have a valid serial number for LV2016 then you should still be able to download and use LV2016.
=== Engineer Ambiguously ===
Message 3 of 11
(5,103 Views)
Hi Bob,
Thanks for your reply,
Yes we have a license for LabVIEW the problem is the last Driver - addon pack available for the Lego
Mindstorm is 2016 version of LabVIEW which I can't seem to download from N.I.
There has to be a workaround out there its just trying to find it
D
Message 4 of 11
(5,044 Views)
Accepted by topic author DenisMoore
This might explain my situation better
I am new to this particular lab so any advise is gratefully received
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P80ySAC&l=en-IE
D
Message 5 of 11
(5,039 Views)
I would assume that package came as VI's or a DLL so it'd work on any newer LV? Maybe it can? I remember installing some addon on an old LV (it didn't have official support for my preferred version) and simply copy the folder to a newer LV and do a mass compile. Unofficial ofcourse, but it worked. 🙂
This process is ofcourse depending on the addon being normal LV code or the right bitness in case of DLL based.
(I think it was the DB toolkit i installed on a 64 bit LV this way)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 11
(5,034 Views)
I finally found an old install for 2016 all is good
Thanks All
Message 7 of 11
(5,012 Views)
how did you install the 2016 version? through uni ?
Message 8 of 11
(1,782 Views)
I downloaded the installer from NI and installed it.
LabVIEW Download - NI
Hope this helps.
Message 9 of 11
(1,740 Views)
I have no access to download the version. I also tried to download 2014 SPI. I have a activation code for it through my uni, but i cannot access the download for the installer for the 2012 SPI version on the NI site.  :((
Is there another way I can use it?
Message 10 of 11
(1,703 Views)
