running executable file in target machine
I have labview 7.1 professional version. I have created a executable file for target machine. When the executable file run at target machine, it needs all drivers and run time engine.
I have installed drivers in target machine but not run time engine.
Do I have to create a installer file which includes run time engine? If I only have *.exe file instead of installer file, how can I install run time engine?
Do I have to put all subvi in the same directory as the one when the program was developed?
Thanks.
(2,960 Views)
I believe that you can install the runtime engine with your original professional version CD. Just choose the custom install and uncheck everything except the runtime engine. If you use the application builder, it automatically puts subvi's where they belong. I've never tried it manually, but I suspect that they need to be in the same directory structure as the one where it was developed.
- tbob
Inventor of the WORM Global
(2,960 Views)
You can download the LabVIEW Run-time engine from the following link:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C1065?opendocument&node=132060_US
Ankita A.
(2,960 Views)
