running executable with Thorlabs Kinesis .net dlls.
I have noticed other post with this same problem, but don't really understand the solutions.
I have a vi that uses Thorlabs Kinesis .net dlls.
When I create my project I make sure the dlls. are located in the same directory as the project.  When I run the VI in development mode, there is no issue.  Then I build an executable and double check the dependencies and see the correct dlls. listed.  When the executable loads (even on the same computer that the development version is loaded) it cant find the dll.s even when you point to the data file that the exe.build created for the dependencies, thus the .net container cant load the user interface.
This is my first post, so I am sure there is a lot more information you would like.  Please let me know
thanks for any help
Message 1 of 1
(1,989 Views)
