running matlab mfile in labview 8.2
Hi
i am working in a project using basically labview 8.2 and i wrote a program in matlab R2008(m file)and i want to run this file in my labview program; i also load this program into mathscript window but it didn't work because the m file contains many functions; i was wondering if you can please help me in this manner.
looking forward to recieving from you
Message 1 of 9
(4,153 Views)
Hi
Does your script written in  MATLAB language syntax return any error ?
Message 2 of 9
(4,147 Views)
what do you mean by "it didn't work because the m file contains many functions"?
try the matlab script node, this block uses the matlab kernel so basicaly everything you type inside this block, it's executed by matlab.
attacked is a program that ends by calling matlab's siso tool.
and works ok.
Mensaje editado por Nihil
Message 3 of 9
(4,141 Views)
Could you post your m-file as an example?
Andy Chang
Message 4 of 9
(4,128 Views)
Hello
first of all my mfile program works perfectly in matlab; I have attached the m file program.
Looking forward to recieving help from You
Message 5 of 9
(4,113 Views)
Accepted by topic author Monireh
worked ok, with me... attached image shows your script, copied and pasted into a mathlab formula node, and the program running asking for the xls file.
did you get that far? if you did, send us the xls so we can go on testing more 🙂
Do you not have the mathlab script formula node? should be in  Mathematics>>scripts and formula nodes>>mathlab script node.
(if you don't have it please tell me)
Message 6 of 9
(4,097 Views)
Thanks for your great help.
Message 7 of 9
(4,080 Views)
Dear Sir, I am facing some same problem here. But when i run my matlab in labview, it shows Error as attach below. I have follow all the instruction but still cannot run properly. Can anyone guide me in this?
Message 8 of 9
(3,393 Views)
Please do not post your question in more than one place. Thread: http://forums.ni.com/t5/LabVIEW/Error-when-running-matlab-mfile-in-labview-8-2/td-p/1955835
Message 9 of 9
(3,377 Views)
