runtime engine
I build runtime engine installer using the "build .exe" tool and I see the following :
  when i try to run setup.exe i am getting install error 1935
What am I missing here? Appreciate your help
(3,027 Views)
Good Afternoon Gyg,
You need to follow the steps in the following White Paper (https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-... under point 5 to create an installer.
Thomas N.
(2,977 Views)
Have you tried installing on a different computer?
A quick google search shows that this error typically occurs if something interefers with the installation, for example another installed programs, antivirus or security software, etc.).
(2,972 Views)
