runtime error
hi
  i am getting this runtime error. refer the attached image.
i was running this code and it was working fine. i just locked the computer for a while and after i came back and tried to run the .vi, it started giving this error.
i have also attached the code.
(3,371 Views)
Does the error persist even after restarting the computer?
When exactly does the error occur?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,368 Views)
You may want to take a look at this KB article.
I've also heard that it's related to NI-Serial 3.0 as well as having older versions of the Run-Time engine.
(3,354 Views)
i copied the block diagram to a new vi and the program did not give any error but since then i haven't logged off.
anyways thanks for replying.
(3,347 Views)
