runtime for LV2009
Does the runtime for LV2009 still show up as a separate entry in add/remove programs dialog?
Is there an entry in the registry that shows if the runtime for 2009 is installed?
(3,047 Views)
Accepted by topic author walleye
The Run-Time Engine shows up as a component within the umbrella category of "National Instruments Software" (that's what you'll see in the Add/Remove Programs).
As for registry entries: HKLM\Software\National Instruments\LabVIEW Run Time. (A forum search would have yielded this answer as this has been asked before.)
Message Edited by smercurio_fc on 02-05-2010 05:18 PM
(3,044 Views)
Thanks for the quick response
(2,991 Views)
