runtime labview
Hey
In labview 5.0 it was possible to create a exe file that runs on machine
without a runtime engine. It was a big exe fil min 2 MB.
But is there an option i labview 5.1 that can do the same??
thanks
E
Click here for Free Video!!
http://www.gohip.com/freevideo/
(3,478 Views)
"E" wrote:
>Hey>In labview 5.0 it was possible to create a exe file that runs on machine>without
a runtime engine. It was a big exe fil min 2 MB.>But is there an option i
labview 5.1 that can do the same??>>>>thanks>E
Not as far as I know. But if the app is not doing anything too fancy you
can sometimes get it to work by putting the lvrt.dll file in the same directory
as the .exe file. I have used this method for a small .exe on a CD-ROM.
Give it a try on a clean PC.
Paul.
(3,478 Views)
I try this way already but it did not work in 2010 version. Do you have other way, please let me know.
Thanks.
(3,029 Views)
There isn't. You build the application by itself. You can create an installer that can automatically install the run-time engine right after intalling your application, but the application itself will not have the Run-Time Engine "built in".
P.S. You're responding to a thread that's 11 years old. In this kind of situation it's best to start a new thread.
(3,021 Views)
