s transform
How to realize a S-Transform block in Labview.
Message 1 of 10
(7,061 Views)
Message 2 of 10
(7,040 Views)
there is wavelet, fft etc.. but no s transform in the list.
Message 3 of 10
(7,030 Views)
The Laplace Transform (which I assume is what you mean by the s transform) is for continuous signals, and is usually used when dealing with mathematical (continuous) functions.  The analog for sampled (discrete) functions or data, which is LabVIEW's domain, is called the z transform -- you can find references to the z transform in LabVIEW Help.
Bob Schor
Message 4 of 10
(6,997 Views)
Message 5 of 10
(6,972 Views)
Nope.  Good point.  However, when I searched "Laplace Transform LabVIEW", I found NI Application Note 39, Linear Systems in LabVIEW which discusses how to use the Z transform, including how to transform a Laplace Transform to a Z Transform.  I suppose it matters what the Poster wants to do ...
BS
Message 6 of 10
(6,953 Views)
My snark was directed at the OP Bob.  It's pretty bad to not know the calculations you want to do.
Message 7 of 10
(6,934 Views)
The s transform is totally different from the laplace transform. Refer atachment.
Message 8 of 10
(6,925 Views)
Have you looked at STFT Spectrograms.vi in the Signal Processing palette?
Lynn
Message 9 of 10
(6,891 Views)
yes. and used the same in STFT. 🙂
Message 10 of 10
(6,878 Views)
