same VIs with different settings at runtime
Ok. So far it looks very good. the first test runs have been successful. I saved an Array of Cluster. Every time I have to save a different setting I replace the setting in the array and then I overwrite the existing file with the new array. So I don't have to access the file multiple times at different positions. That works fine for me.
thanks very much so far..
Message 21 of 21
(279 Views)
