same code for every state in event
Hello.
In my front panel there are some buttons that will give the same result each time they are pressed.
Exactly like menu items.
In every state of my FSM there is an event structure. Is it efficient to add a case for every menu item and buttons for every state?
Is there a way to add this functionality in just one case structure and then make it global somehow?
Thanks.
(3,578 Views)
Accepted by topic author vakost
Hi vakost,
don't use an event structure in each case. Use only ONE event event structure!
Read about Producer-Consumer scheme. Read about QDSM (queue driven state machines)! That should give you a kick…
(3,572 Views)
Thank you very much for the quick reply!
I am sorry I got confused with the double post.
(3,562 Views)
Thanks are given with kudos.
And interestingly enough LabVIEW R&D was actually thinking about having LabVIEW not allow more than one event structure in each VI to help avoid this type of issue.
http://lavag.org/topic/17781-suppose-we-limited-1-event-structure-per-block-diagram/
(3,527 Views)
