sample to read with sample rate 100khz
Hi
I would like to do a continuous acquisition of 32 channels. I want to do this acquisition with a sample rate at 100kHz
But have to know the sample to read. I tried with 1k, 2, 5k, 20k, 50k and I always the same message which says that my data are no available because my data was overwritten.
If someone can tell me what can I put like value for the sample to read, it will be very useful for me.
My card ; Ni pxi 6115, min rate sample = 20kS/S, max rate sample= 10Ms/s , inpuit fifo buffer= 32Ms
Thank you very much
Romaric GIBERT
Message 1 of 16
(3,894 Views)
Hi Romaric,
Please share your source code to have a better idea about the system and to identify the root cause of the error.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 2 of 16
(3,889 Views)
Here is my code
Message 3 of 16
(3,887 Views)
Hello Romaric,
I check here your code is working fine. In your code no wrong steps.
I hope you are doing some mistakes for debugging purpose like you have some proves in your acquisition loop or you run your code in high light execution mode. I suggest you remove your all proves and highlight execution if these are there and then run your code. it will work
Thanks and Regards
Message 4 of 16
(3,876 Views)
thank you for your response but I have some difficulties to understant that you wrote
I don t know what is "prove " can you explain me please?
Thank your very much
Romaric GIBERT
Message 5 of 16
(3,872 Views)
He meant to say "probes".
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 6 of 16
(3,862 Views)
I m sorry but I don t know where are the probes on my VI
could you say me please ?
Thank you very much for your help
Romaric GIBERT
Message 7 of 16
(3,861 Views)
You may not have any (probes).
 He was refering to the use of the LabVIEW diagnostic feature where you right click on a wire and select "Probe" from the menu.
This allows you to see the value of the wire when it executes.
There is a slight delay caused when you "probe" a wire. This could cause problems in time sensitive applications.
Your application is missing the file: Log_Channels.
Message 8 of 16
(3,857 Views)
Here is log and channel
Thank you very much
Romaric GIBERT
Message 9 of 16
(3,855 Views)
PS : I haven t no probes. If you could help me please
Thank you very much
Message 10 of 16
(3,853 Views)
