sampling signal in labview?
How i can to sample a signal in labview?
For example if i have a signal in array of data (dbl) and i want to sample this signal how i can do this?
Thank you .
Message 1 of 11
(8,558 Views)
What do you mean?
Your signal is already in an array - what do you want to do?
Message 2 of 11
(8,555 Views)
Hi Sarah,
what exactly do you want to achieve?
What is your goal with those data in the array?
(Just a guess: Use an autoindexing loop to access the elements in the array one by one…)
Message 3 of 11
(8,549 Views)
I have my signal in array and i want to sample it in graph like this:
Message 4 of 11
(8,546 Views)
Hi Sarah,
decimate your signal as needed!
Maybe ResampleWaveform will do what you need…
Message 5 of 11
(8,523 Views)
Ok, But how i can get in Resample Waveforms ? ?
 Knowing that I have a random signal.
Message 6 of 11
(8,517 Views)
Accepted by topic author Sarah_LAB
Hi Sarah,
you could convert your array into a waveform.
Or you search for similar functions in the signal processing palette, which work on (1D) arrays…
Message 7 of 11
(8,512 Views)
In the Signal Processing->Signal Operation palette, there is a couple of Decimate VIs for you to choose from.  These should do what you want.
Message 8 of 11
(8,487 Views)
here you go.
Attached is the vi.
Waiting For the inner calling 🙂
Message 9 of 11
(8,461 Views)
a slight change in interpolation view for the plot is neccessary to match the graphs you have posted.
Message 10 of 11
(8,451 Views)
