save 2 different power spectrum in a single graph excel
Good Mourning, well I´m trying to plot 2 power spectrum in a single graph in excel usin the report generation toolkit, the problem is that I can't plot the second because the first plot already contain a 2-D dimension array and I can't figure out how to add the second plot in the Excel Insert Graph VI.
My VI consist in 2 simulate signals going to a power spectrum, the spectrum saves when I push the save button in the front pannel.
Thanks and greetings.
(3,519 Views)
No one knows what to do? Or should I look another way to save my spectrum.
Please any idea works.
(3,479 Views)
Good Morning Rolando-stc.
In order to show multiple plots in a single graph in Microsoft Excel you need two create a 2D array. The first row will be the "X axis" values and the next rows will be the "Y axis" values for each plot you want to show.
I attached an example. Please, check it.
Regards.
José Manuel Vólquez R.
Applications Engineer, NI México.
(3,462 Views)
Thanks a lot JoseManuel that do the trick in the power spectrum graph, but now I can't plot the x-axis in my amplitud vs time graph.
The x-axis contains real time data, but excel only shows a number 3.4e9 and zeros, I tried with a property node and Get Date/Time in seconds.vi but nothing.
I hope you can help with this new problem.
Greetings!!
(3,456 Views)
Good Afternoon Rolando-stc. The only thing that you need to do is to create an array with the information for your X axis.
Please check the image below. This is an example of how you can modify your application to add time information for the X axis.
IMT José Manuel Vólquez R.
(3,423 Views)
Muchas gracias por tu respuesta en ambos foros, pero sigo con el mismo problema ya que añadiendo los vi que me indicaste y colocando los vi de tiempo real y Get Dynamic Data Atributes me sigue apareciendo en todo el eje X el número 3.4e9.
Todo el fin de semana estuve en esto y pues no tengo ni idea de que esté haciendo mal, espero que me puedas seguir apoyandome.
Saludos y gracias.
(3,398 Views)
