save LabVIEW VI from 8.0 to 7.1
Is anyone can save these 2 vis in Labview 7.1 for me (8.0 -> 7.1), it would be appreciated.
I only have Labview 7.1.
Thank you very much.
Regards
Adrien
(2,762 Views)
Hi adrien, I was able to convert the two VIs for you.  However, since I did not have the sub VI files I could not convert those.  If the sub VIs are saved in version 8.0 I'm afraid that you will be unable to run them in 7.1.  Hope this helps!!
Nick B - NI Intern
(2,722 Views)
Thank you for the conversion Nick.
Indeed seems like there is a lot of subVIs... so I'll ask the guy who gave me these 2 VIs to send me all the subVIs in version 7.1.
I think that would be ok.
Thanks a lot again.
Regards
Adrien
(2,696 Views)
