save a string to file
- Since the program will run only one interation after you push "Start", you can add the save functions at the end of the program. Not that your program will stop and you have to start it all over again.
in which way can i do it?
Using LabVIEW 7.1
Message 11 of 19
(1,619 Views)
Wire the Datalog to a Save to text file.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 19
(1,611 Views)
but i wanna a button 🙂 i don't want always save my data in file...and i can't use event structure
Using LabVIEW 7.1
Message 13 of 19
(1,609 Views)
Then put the save file in a case structure. 🙂
/Y
Qestit Systems
Message 14 of 19
(1,601 Views)
You can do your task in various ways. However, if you want to minimize code changes, consider putting at the end of the existing code a further while loop similar to the one managing the measurement start. In the new loop, the conditional terminal should be connected to the OR of the Save button and a new Stop button outputs. If Save is selected, create the output file (in a case structure) and exit; if Stop is selected, just exit.
Not the best code I could think of, but certainly meets the boss' requirements Smiley Wink
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 15 of 19
(1,597 Views)
can you show me please?
i know that for you it's obvious, but i'm learning labview from not-so-much 🙂 i used always event case
Using LabVIEW 7.1
Message 16 of 19
(1,593 Views)
It's very easy indeed:
Paolo
Message 17 of 19
(1,585 Views)
thanks 😄
Using LabVIEW 7.1
Message 18 of 19
(1,578 Views)
You can simplify slightly by using a 2 button dialog box instead of the loop.
/Y
Qestit Systems
Message 19 of 19
(1,568 Views)
