save content of picture control as .jpg into excel file?
Is it possible to save the contents shown of a picture control as a jpeg file into an excel file along with other data? Is this possible without using ActiveX? If I have to use ActiveX how do I use this?
Message 1 of 8
(3,682 Views)
I don't know of any way other than Active-X. There is a nice Active-X control available quite reasonable by e-mailing kusluski@mail.ic.net. I have used it to insert pictures into Excel spreadsheets with good results. It has quite an extensive set of options to do just about anything I have ever wanted to do with Excel.
Good luck
Message 2 of 8
(3,682 Views)
Hello AndyBE,
ActiveX is definitely going to be your best bet. I�ve attached an example that should meet your needs. Let me know if this works for you.
Have a nice day!
Robert Mortensen
Robert Mortensen
Software Engineer
Message 3 of 8
(3,682 Views)
Hi Robert!
Thanks for the example. Unfortunately I can not find following vis on my pc:
Read BMP File.vi
Read PNG File.vi
Read JPG File.vi
Row Col to range.vi
Write JPEG File.vi
Write PNG File.vi
Where do I find them? Is this a question of the version?
ANDY
Message 4 of 8
(3,682 Views)
Andy,
This example does rely on the VI�s you listed, which are unfortunately not available in the Base Package, which I am assuming you have. You will have to upgrade in order to use them. Otherwise, you will have to implement the .jpg format yourself.
Robert Mortensen
Robert Mortensen
Software Engineer
Message 5 of 8
(3,682 Views)
Robert,
I noticed that all off the vis regarding a the png or jpeg format have (excel) added to the file names thats why LV couldn't find the vis. So I have those vis. But I wasn't able to find the Row Col to Range.vi. Is this in the LabVIEW package or is this a customized vi? If it is customized. Is it possible for you to provide it?
ANDY
Message 6 of 8
(3,682 Views)
They're all part of the "Report Generation Toolkit for Microsoft Office" addon to LabVIEW
Info on it is at http://sine.ni.com/apps/we/nioc.vp?cid=5769〈=US
Fading out. " ... J. Arthur Rank on gong."
Message 7 of 8
(3,682 Views)
Andy,
Donald is correct. I apologize for sending you an example that relies on the Report Generation Toolkit. The (excel) versions of the VI�s you do not have are not the same as the ones you do have. You will need the toolkit to run this example. However, the differences between the VI�s are not great. It looks like they simply modify the data to match the form that Excel wants. You can either purchase the toolkit or rewrite those portions yourself. Good luck!
Robert Mortensen
Robert Mortensen
Software Engineer
Message 8 of 8
(3,682 Views)
