save data and update in ACCESS
Hi all : Attach see this vi … I create I table in access for limit configuration ,,, I succeed to read the data ,, but I want to change some specific value when from labview and saved it again in the same file in access in the same table  How can I do that in Labview update or saving data
Please when you run the vi choose the correct path to recall the data
Message 1 of 9
(4,402 Views)
Your VI shows that you have command of the property nodes. Looks like all you need is the AddNew property of Recordset. See attached.
Richard
Message 2 of 9
(4,396 Views)
Hi :
first of all thank you for your fast response
can you help me with the vi ,, I am new in this section .. What I want to do to change for example Min value ( volt) from 1 to 3 and save it in same table
and every other value can be update in the same way
thanks very much again
Message 3 of 9
(4,388 Views)
If you just want to change values, you can use direct SQL commands. See the attached screenshot. Note the mentioned website for commands. With a few simple property nodes, you can do what you need.
Your mdb file does not open for me, so I can't make this for your specific table, but you should get the idea.
Richard
Message 4 of 9
(4,373 Views)
Hi  First of all I appreciate your help : But may be I not explain my need very well … I want to update the value from the table it self ,, what I mean I explain in step 1-       after I load the data from access file , these data loaded in table 2-       this table is as indicator so I can't change value
3-       I want to control on this table ac control . and if I want to change specific value for example row 0 , column 1 ,, I change it from table and then this new value update in access file
   I hope I explain this problem well now
Again thanks a lot
Message 5 of 9
(4,354 Views)
Hi :
I try to do what you send for me but always i get error
attach see file please ,,
Message 6 of 9
(4,350 Views)
Hi again
please tell me what i am doing wrong ?
thanks
Message 7 of 9
(4,341 Views)
Take out the %s after Data Source=
Richard
Message 8 of 9
(4,333 Views)
Hi : This is related to same issue  I have little question … I set password to my access file for update protection  … attach see file please … I do another thing to load user name into list …
My problem is :
 When I set password I the list sign is disable  but when I cancel the password I can choose user name through the list
My password for access file is : 1
what's i am doing wrong
thanks you very much
Message 9 of 9
(4,286 Views)
