save data continuously in a certain format
I'm new to labview and I have two questions at the moment...
1). I'm trying to save a continuous time history data at certain interval (let say every 30 minutes or 1 hour). How can I do that?.
2). Another thing, I'm trying to create a vi so that I can choose the type of data to be saved (like a pull down menu for the user to choose from.. eg. ascii, binary, text etc...). Is is possible to do this?...
Thank you in advance...
Zainah
(3,144 Views)
1) inside a loop use:
- Get Date/Time String.VI to obtain the date and time
- Concatenate Strings.VI to add separators (for example End Of Line after TIME and a space between DATE and TIME)
- Write Characters To File.VI to save obtained string (use APPEND = true)
- Wait.VI or Wait Until Next ms Multiple.VI (more accurate) for your delay
- do not forget the end condition for the loop
2) it is possible ... use a Menu Ring Control wired to a CASE structure and insert different file related operations in each CASE according with selected item in menu. Also, you might want to put the menu ring inside a loop (block diagram) in order to be able to decide the moment of saving data to file
Finally, take a look in lv folder\examples\general and \examples\file\
to have some guidelines.
good luck
(3,144 Views)
Thanks Lab Viewer... for your suggestions... I'll try them... (in the process now..)
Thanks again...
(3,144 Views)
Regarding your 2nd question, I can mention an alternative method I use these days. I had the same problem some weeks ago and Brian Vibert solved my problem with a very nice VI!!! I modified it to fit my needs and I attached it to this message.
Run the Test.vi that will call up the SaveAsTypev2.vi which basically is the standard "save as" dialog with a drop-down menu of file formats that you can specify your self.
Hope this helps. /Mikael
(3,144 Views)
Thanks Mikael....
(3,144 Views)
