save data continuously
I am trying to save data acquired continuously at a sample rate of 1000 points/0.1s. Unfortunately, the vi below only allows me to save the first 1000 points. How could I manage to save the rest of the samples following each other?
Ninjatovitch
(3,698 Views)
there is one issue, you are trying to write into a new file in every loop. It is better if you take the save into file out of the loop and use a shift register in the loop to store the data.
check the attached VI
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,679 Views)
Hi Anil,
Thank you very much for your help. Unfortunately, I can not open your vi because I have got the 8.2 version of LabView. Is there a possibility that you could send it to me in an older version?
Best,
Ninja
(3,675 Views)
Accepted by topic author Ninjatovitch
Anil Punnam
CLD
(3,672 Views)
