save data to array
帖子被trinight在02-19-2006 07:14 AM时编辑过了
(3,961 Views)
Not sure what you want. If you want to save the random figure in a array you can set the output tunnel to 'enable indexing'
But maybe that's not the question, because I can't read it.
(3,926 Views)
Hi, K C.  In another post I got some examples. In my case , I have a data source which outputs two numbers at a time(like 8.2 9.6), then after a fixed time interval, it outputs another two numbers...... I want to keep these numbers in a two demention array. I attach a example(add to array.JPG) from someone(in another post you can find the details) which has a fault , that is if two same number come along, it can only save one to the array. I attach another image of vi which I made myself(add to array[1].JPG), which has a fault too, I didn't know why, wish you can help me. Tomorrow I will go out for several days. So I cann't reply in the following days.Smiley Tongue
(3,910 Views)
Do you actualy get the numbers in a string like:  8.2 9.6  or do you get two numbers as a numerical?
How is this VI for a start ? (I hope you have LV8)
Message Edited by K C on 02-24-2006 01:37 PM
(3,899 Views)
