save data to excel file
i am trying to save data to excel file attached file shown bellow.
However I couldn't do that.
please tell me the solution.
Message 1 of 11
(4,069 Views)
Hi xaviar,
However I couldn't do that. please tell me the solution.
The solution to what? "I couldn't do that" is surely no LabVIEW error message…
Your VI runs fine for me. (After I renamed it using only pure ASCII chars for the filename: keep in mind using asian chars will likely give problems to the rest of the world!)
Why can't you save your data?
What is the problem?
Did you get any error messages?
Message 2 of 11
(4,063 Views)
Dear GerdW
Thank  you for your reply.
As you said, this program is working
but when it finish running the program,
data was not saved even if i open excel.
Could you tell me why data was not saved to excel?
Message 3 of 11
(4,056 Views)
Hi xaviar,
No, I can't.
As I wrote before: your VI is running fine for me. I get an Excel XLSX file in the exact place I configure in the ExpressVI…
Message 4 of 11
(4,049 Views)
Dear GerdW
Can you save the data in the specified excel file?
Message 5 of 11
(4,046 Views)
Yes.
That's what I get after running your VI for some seconds:
(I added the plot in Excel to visualize the data…)
Message 6 of 11
(4,043 Views)
Dear GerdW
in my case, I got an error message when I push the running button.
Do you know why ?
Message 7 of 11
(4,039 Views)
Hi xaviar,
Do you know why ?
No. Don't know where this message is coming from…
Just an idea: Do you have Excel open when starting your VI? Can you make sure Excel is closed!?
Message 8 of 11
(4,036 Views)
Dear GerdW
Do I have to keep open Excel file while running the program?
Message 9 of 11
(4,034 Views)
Accepted by topic author xaviar_nao
Hi xaviar,
no, you don't need to keep Excel open.
- You don't need Excel at all when running this VI.
- If Excel would be opened and if Excel is used to analyze the file created by your VI it would block your VI from changing this file: that's why I suggested to close Excel…
Message 10 of 11
(4,031 Views)
