save data to excel
here is 2019 version
Message 11 of 19
(1,206 Views)
Accepted by topic author tominsek
Hi Tim,
Thanks.
Try this:
Add the column headers as row before the item string array: as you write the whole MCLB content at once there is no need for two file write calls.
And I guess from your images there are EOL chars in the SQL data: remove them before creating CSV files!
Yes there are EOL chars:
(Maybe you should delete the EOL chars right after reading from SQL DB?)
Message 12 of 19
(1,200 Views)
Gerdw
how do i delete EOL chars?
Message 13 of 19
(1,194 Views)
Hi Gerdw
we are closer to the solution...
the data are written in only one column in excel. it needs to be written 1 thing in 1 column
Message 14 of 19
(1,184 Views)
Hi Tim,
I embedded an image in my message…
(The function is called TrimWhiteSpace.)
Other stuff:
  • Don't hide labels in the block diagram.
  • Don't place too much code inside case structures, especially when it is the same for all cases:
  • Are you sure you need a timeout between VISAWrite and VISARead?
  • You really should handle statemachine data in a cluster in a shift register! No need for all those local variables in the "SQL" state (and others)…
  • Are you sure you need more than one event structure in this VI?
Message 15 of 19
(1,182 Views)
Hi Tim,
Now you are running into Excel-internal problems!
Your Excel doesn't handle the TAB delimiter (default in LabVIEW) as it should.
I guess it expects a semicolon instead (as my German Excel does).
You can easily define the delimiter at the WriteSpreasheetFile function!
Message 16 of 19
(1,178 Views)
Hi Gerdw,
Thank you the only problem was that i needed to set delimiter in write delimited spreadheet to ( ; ) and now it works,...
Very thank you
Message 17 of 19
(1,170 Views)
Someone helped me with this programm because im new to labview and honestly speaking i dont really know what im doing haha...
Message 18 of 19
(1,167 Views)
Don't worry, most of us who read your posts knew that ...  Please teach him (or her) what you learned from us.
Bob Schor
Message 19 of 19
(1,113 Views)
