save data to file at a slower sampling rate
I tried your example and I still got all the values.  It basically copied the whole first row and removed the second.  There must be something I'm missing
Jordan
Message 11 of 13
(593 Views)
I think I see what is happening in your data.  You have each data point by column so that the data stretches to the right in time rather than down.  I didn't catch that when I wrote up the VI.
Put a transpose array function before and after the loop.  This will swap row with columns temporarily so that the loop will effectively act on the other dimension.
Message 12 of 13
(586 Views)
Oh My!!...it works.  I set the transpose on the read spreadsheet to true and now it works beautifully.  Thanks for everyones help, much appreciated.
Thanks again,  Jordan
Message 13 of 13
(567 Views)
