save .dll on library
Hello all!
I have a little problem... I usually save my VI's into llb (Save with Options -> Development Distribution) and everything is perfect but I had a problem recently with a VI that needs a dll and this one is not saved into the library. When I tried to open my VI it didn't work because it kept calling this dll.
Can this be done? How?
Thanks for your answers,
Isabel
(3,202 Views)
No, you cannot save a dll into an llb. The llb was originally used to get around the limitations of file name length in windows 3. You can distribute the llb and dll together as a zip file.
I hope you are using the llb only for distribution. Saving a project in development into an llb instead of separate VIs in a folder is a bad idea. A single corrupt VI can make the entire llb unreadable.
(3,199 Views)
Yes I only use the llb for distribution, it's much more easier. I just wanted to know if it was possible to integrate the dll and I have my answer.
(3,194 Views)
