save file with fixed file extension
in my programme the user should put in the name of a file which will be saved. The file extension name should be automatically added to
the file name, example:
the user put in "Log0001" and the complete file name is "log0001.csv"
I tried the following function:
for type I used  a constant with ".csv", but this doesn't work, the error message was: "Set file and program type in Param-nethos.vi<APPEND>
Logg0001"
Is this the right function for my requirement or are there other possibilities?
Message 1 of 10
(3,496 Views)
Just use Concatenate String to add ".csv" to the file name and then build the path as you do now.  Then you can create/replace/open the file.
GCentral
Message 2 of 10
(3,460 Views)
Hello crossrulz,
thank you for your replay.
But how could I adding the extension using the base path control?
I tried the 'Build Path' function, but this doesn't work:
Message 3 of 10
(3,424 Views)
Try something like this:
Also note that this does not check for illegal characters in the path or name
=== Engineer Ambiguously ===
Message 4 of 10
(3,409 Views)
Build Path adds another layer to your path. The file path you would get out of that would be something like:
..\some_base_path\.txt
Convert the path to a string, and use the Concatenate Strings function to add the .csv to the end of the file name. Alternatively, you could use the File Dialog express VI to put up a dialog for the user. Using that, you can specify a default file type. Depends on your use case.
Wes Pierce
Principal Engineer
Pierce Controls
Message 5 of 10
(3,405 Views)
Hi Wes,
No!
Don't convert the whole path to a string just to manipulate a filename! That's where StripPath/BuildPath come into play!
(Converting a full path to string may/will fail once you run the code on a different target, like changing from Windows to MacOS or LinuxRT!)
Message 6 of 10
(3,390 Views)
Great point. And I completely agree - the benefits of using the path file type and associated functions for cross platform (or even cross-locale within windows) are super important. I was responding the the above comment in mind - using Concatenate Strings. That function won't work on paths, hence the conversion. But 100%, only convert the piece of the path you need, using strip and build path.
I suspect though that the file name comes into the application as a string from user input, so in that case the extension should be added before a full path is ever created.
Wes Pierce
Principal Engineer
Pierce Controls
Message 7 of 10
(3,383 Views)
Accepted by topic author abue
I think he meant, don't convert the whole string to a path. Using Strip Path returns just the filename as a string. Example:
And if you want to be extra safe, use "Get file extension" instead of "Strip path":
This method will take "C:\MyTest.txt" and turn it into "C:\MyTest.csv". The "strip path" method would return "C:\MyTetst.txt.csv".
Message 8 of 10
(3,374 Views)
I am working on Win7 using LabVIEW18. But hopefully this can help you.
I simply use a build path function. Wire your path into the upper terminal. On the front panel place a string control(this is where your user will input their file name). On your block diagram use a concatenate string to append the file name and extension together. Wire those into your build path. You can double check the outcome using an indicator before moving forward. Then I use the open file function, with a constant of your choosing(whatever is needed in your situation), for the example below I used Create/Replace. I wrote to the file and then closed the file, saving it to the path name created earlier.
I hope this helps.
Creig Mills
Culverson.com
Message 9 of 10
(3,360 Views)
thank you very much for your support, i decided to use BertMcMahan's last solution.
This is perfect for me.
Message 10 of 10
(3,343 Views)
