save frame when pressing the button
Helo,
I'm acquiring a .avi video from a webcam and I'd like to save a frame of this video whenever I press an 'acquire button'. I'd like also to save the acquired frame in separate files (for example, frame 1 in image1.png file, frame 2 in image2.png file and so on).
Any suggestion?
Thanks!
Message 1 of 16
(4,217 Views)
Elena,
do you have NI Vision Acquisition?
Norbert
Norbert
Expert: Geometry
Message 2 of 16
(4,204 Views)
yes I do
Message 3 of 16
(4,192 Views)
Then verify that you have access to the Vision Development Module. This gives you specific functions for AVI.
I think this should provide you with all requested functions.
Norbert
Norbert
Expert: Geometry
Message 4 of 16
(4,189 Views)
this is the first attempt (see attachment) , but I don't know how to 'grab' the frame, this confiuration gave error while running when I press the 'acquire' button
Message 5 of 16
(4,186 Views)
Never worked with the assistant (blue expressVI) so i am not sure what the source of error could be in specific.
The basic functions you require are in the AVI palette as well as in the IMAQ or IMAQdx palette, depending on the camera you are using. Both supply a "grab" function.
Norbert
Norbert
Expert: Geometry
Message 6 of 16
(4,182 Views)
The express take the images from the webcam, that is it. I try the 'grab' but it says that 'NI-IMAQ:  The passed in interface or session is invalid' .. how can I pass it correctly?
Message 7 of 16
(4,180 Views)
Hm, working with screenshots on code is rather difficult. It seems to me that you are using an additional "Grab Acquire" which is definetly not correct if the express VI already returns a proper image from the camera......
Norbert
Norbert
Expert: Geometry
Message 8 of 16
(4,176 Views)
Now I can see the frame when I acquired it but I can't save it 'File access denied' .. any idea ? (see attachment)
Message 9 of 16
(4,157 Views)
Well, your filepath constant for the IMAQ Write File 2 function contains an invalid path since it does not point to any file on disk. A file path to disk is always absolut, so it has to contain e.g. a file letter (like "C:\").
Another thing you have to consider is that you are going to use the same file for all images, simply overwriting previous ones. I doubt that this is the feature you are looking for....
Norbert
Norbert
Expert: Geometry
Message 10 of 16
(4,144 Views)
