save image file in sequence
Hi, attached is my save image file VI. I want to save the images at a pre-selected location and do that continuously without interruptions or prompting, for say 20 pictures. I have places the vi into a for loop but here is the difficulty: the vi will ask the user to give a name for the image file. Is there a way that the images will be named "1, 2, 3 ..." and have everything done automatically?
Message Edited by kevinhy on 03-07-2005 04:12 PM
Can a computer learn how to program?
(3,052 Views)
I am not able to view your VI as I am using LV7.0.
However, I hope the attached Vi should be able to give your some clues...
Filepath input to your save picture function must be wired with a filename.
Empty path will causes a prompter!
regards
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,039 Views)
Hi Ian,
Thanks a lot! with slight modfication from your code, I am able to do what I need to do, thank you for being a great helper!
(3,027 Views)
you are most welcome! 🙂 Cheers!
Ian F
依恩与LabVIEW
(3,018 Views)
