save in file
hello,
I have a labview student edition 8,2 that I recently got from school and it's the first time I work with it so...
We have to make a simple program, like a small calculator.
Then we have to save the result in a file. But I can't manage that.
I think it has something to do with write file and a file path ...
That's what I have allready, I also used a subvi, but I'm not sure if I did it well
Can someone help me???
(2,904 Views)
Hi..
If you want only save a text message , you can use the Write Text function (control palete  \ file i/o \write text).
As the same way, you can read text message too.
I sent you an VI example attached, and a Text file to try the open function too.
Regards
Julio Ribeiro
(2,893 Views)
Thank you Julio
(2,870 Views)
