save measurements vi
The following VI is a short version of a larger VI where I have two "double [64 bit real]" inputs (DBL wires) that I am trying to save into the same file. Here I just substituted them with two random value generators. What I'm getting so far is both measurements saved on the same column in a spreadsheet, but I'm trying to separate them into two columns to do further analysis in Excel. Do you have any suggestions?
Thanks in advance,
Valls
(2,770 Views)
Instead of using Build Array and Convert To Dynamic Data join your two data items using the Merge Signals function on the Express --> Signal Manipulation pallette.
Allen
(2,766 Views)
Great! Thanks!
(2,758 Views)
