save million datas in one sec
any .vi example with pre writing to binary file? Smiley Frustrated
Message 21 of 24
(657 Views)
First, let's clean up the mess.
  • In your toplevel VI, you already write to a binary file in the lower left corner. Do something similar.
  • How is this called? Does it get called once per second, creating a new histogram with every call?
  • Are you overwriting the same file with each call?
  • Your histogram code has way too much garbage. Looks like a donwconversion from an in place element structure to an old LabVIEW version. You can delete the inner while loops.
  • What is the purpose of the FOR loop in the save subVI. All it does is thrash the memory. Can you explain why it is there?
Message 22 of 24
(649 Views)
@altenbach: thanks for the quick reply.
The purpose of my last question here is actually not regarding the first post in this thread anymore. But I tought, this is the basic that I still dont understand. Thats why I'm trying to ask for example in this thread.
What I'm trying to do is:
1. Acquiring data samples with a digitizer (done)
2. Save the data that I got from the digitizer into a file, and reffering to the sampling frequency of the digitizer (ex.: 4MSamples), which means it would plot 4 million points in 1 sec running, right? If I would save the points in a file, what is the best way to do it?
I've tried to simulate it by generating sinus wave using sine waveform.vi with random amplitudes in a while loop with certain delay (in test CIC2.vi), then I wanted to save the generated waves (array of time and amplitude) into a file. Then I increase the sample rate and the number (ex.:1M ), and decrease the delay to 250ms (I'm trying to get 4Million points in 1 sec).
When I do this, and look at the task manager, the memory allocated for labview is increasing very fast until it reach a limit, then labview gives me this: "memory is full". Im not even saving the points yet.
Simply said: I want to save acquired 4MSamples/sec without getting "memory is full", what is the best way to do it?
regards,
Yan.
Message 23 of 24
(641 Views)
hi everyone,
I think I have found want I need. Just using combination of examples:
- niScope EX Fetch Forever.vi
- TDMS Data write.vi
But maybe I could get a little help about reading it back to work with the datas. With using TDMS I can save million points every seconds, but to read it back in one big file seems very problematic with memory. I've been looking here (http://forums.ni.com/t5/LabVIEW/Memory-usage-problem-with-TDMS-files/td-p/1907261). But seems there is no help yet either.
Maybe anyone can guide me to any tutorial with data splitting or anything like that?
regards,
Yan.
Message 24 of 24
(601 Views)
