save modified sub-vi without affecting the original sub-vi
Hi
I m a novice labview user..i have got few llb's and i m making my labview program using sub-vi's in those llb..sometimes i want to modify a sub-vi and just save the modified sub-vi in the master vi only..i dont want that change to reflect in original sub-vi..
appreciate your help
(2,570 Views)
First, you should not be using llb's for development. Convert them to a folder of VIs. Second, what problem do you have with the Save As dialog?
(2,563 Views)
Well, SAVE AS would save the the complete VI including the modified sub-vi' but the modifications will also be reflected in the orginial sub-vi in llb's which i dont want..do you mean to say that i should separtely save the modified sub-vi somewhere but that would be time consuming as i have 100's of sub-vi's..i though there would be a easy way i m unware of
(2,553 Views)
100's of subVI's?
How time consuming can saving 100's of subVI's to a new location or a new file name be compared to the time it takes to modify the 100's of subVI's?
Another alternative is to drag out and copy all of your subVI's to a new location first (not in an .llb), then go through and do the modifications.
(2,550 Views)
ok ..well i agree i can do that...its just irrttating and increases complexity.....the benefit of llb is that its there in functions/palletes so i can simply drag/drop a sub-vi....do the changes to my sub-vi while having a completer picture of master vi...
i guess i will save all the sub-vi to some place else from llb and go abt it..
(2,546 Views)
