save plot/graph as JPEG or other image file
Is it possible to save a plot / graph as a Jpeg or other image format??
Insteat of writing to a spreadsheet file??
(3,921 Views)
I've done somthing like that in one application and the example it's on the attached pic.
basically it's:
1 - create graph reference (right click and choose create reference)
2 - pick a method called "get image"
3 - save the image to file.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,899 Views)
And you should probably avoid JPEG, as straight lines and text come out bad.
PNG is both compressed and lossless and would probably be better.
___________________
Try to take over the world!
(3,891 Views)
Thanks for the quick respons,
but, where can I find get image??? i use labview 8.2
(3,888 Views)
I have found it,
Thank you for your help it works perfectly! Smiley Very Happy
(3,868 Views)
