save strings and time stramps to file
Hi guys,
I have a VI in which I have made a log file containing names and time stramps I would like to save those into a file an excel file would be good having to columns but I face a problem of how to insert the strings into the "write to measurement file " how can I deal with it please help me thank you
(3,927 Views)
Do you want an Excel file, or is a CSV file sufficient?
To create a CSV file, use the Write Delimited Spreadsheet function. This is available at the top level of File I/O on newer versions of LabVIEW (at least since 2016, I think also 2015. For previous versions, it has a different name but there is a similar function).
The default delimiter is 'Tab', so you should wire a string constant value of ',' instead for CSV. For a log file, it's likely you want to set 'Append?' to true (the default is false). You can wire 1D or 2D arrays of strings straight into this function and it will write them to a file for you. You have to pass it a path - you can't give it a file reference, so if you need to write very quickly, you should do the formatting yourself and use the Write Text File node instead.
If you want a true Excel file (rather than just a file that opens in Excel) you need to use either ActiveX or the Report Generation Toolkit. ActiveX would be much more complicated - I wouldn't suggest it to you.
GCentral
(3,910 Views)
Hi, thanks for your reply
but I have a question  can I write the current time next to the string ?
because this is what I'm after
or do I need to stream the data in one line after converting the time stramp to string and then use the delimiter and then combine them both ???
(3,904 Views)
Use a FOR loop to convert your time stamp into a string.  You can just add a comma (or tab) and your string to at the same time.  You can then use Write To Text File to write your data.  Just be sure you open you file before your main loop starts and close it when you are done.
(3,895 Views)
Accepted by topic author AnouarDTH
You can convert a timestamp to a string directly if you want, but the timestamp probably wouldn't be very useful. I suspect that what you want is either the Format to String node with a time format, or some use of the Get Date/Time String. I always prefer the Format to String option.
Assuming you just want a message and a time string, something like this should work out fine:
GCentral
(3,889 Views)
thank you so much guys for your help
(3,879 Views)
