save strings in tdms format
hi everybody!!
can i save an array of string in tdms format???
how can i do it??any example??
(3,268 Views)
You can save a string array in .tdms file in either of the following two approaches:
  • Save an array of string in a "string data type" channel;
  • Also you can choose to save an array of string in the form of properties.
The string data type channel is a simple way to store a string array, shown in the picture below. The channel is natively an array of elements of the same data type.
I wrote an example VI to demonstrate the both ways to save a string array, you can refer to the attachment VI for details.
(3,245 Views)
