save variable value in excel file
i use labview program to control a instrument, then, i save data collected from the instrument in an excel file (see the top picture). so far, i can save data in excel file, but i do not know how to save parameters (these parameters are used to control the instrument) into the excel file. could someone please help me?
Thank you
(3,020 Views)
You aren't saving an Excel file. You are saving to a text file with tab delimited data. You don't mention exactly what the parameters are or how they are stored but if they are in a string array, you can simply write them as another row. The Write to Spreadsheet File can be called multiple times so call it once to write the header and again to write your transposed data.
(3,010 Views)
