saved csv file
Hi all :
Please see attach file , I build vi that create csv file , if you look at this vi you see that I saved 5 row every time after I press on go bottom , if I press again on go another number replace the old number in same file ,
What I want to do if I press on go bottom for the second time  number will saved under row no 5
Example when I press on go in the first time, number saved from row 1 to 5, that's I can do  , but if I press on go in the second time I want these number will save from row 6 to 10
Can I do that ?
(4,025 Views)
Use the open file VI to open the file.  Then use the Set File position to set the file position to the end of the file.  This is found in the advanced File I/O pallette.
I would also recommend using the build path function to create the file name rather than the path to string, string manipulation, then string to path functions.
(4,005 Views)
can you help with this issue
thanks
(3,975 Views)
Hi elyan,
that should give you a kick...
Notes:
- make your diagrams smaller...
- ALWAYS use "Build Path" / "Strip Path" functions!
(3,968 Views)
thanks very much
(3,959 Views)
