saving activeX object
Hi to everybody, I am trying to build an installer and in the middle of the process it is stopped showing the next message: "An error ocurred while saving an activeX object".
Can anybodody tell me why can it be happening?
I am using LView 7.1.1.
Thanks in advance
jm
(4,871 Views)
Are you sure the activex object is registered with windows
(4,857 Views)
Yeah, I think so.
More information about the error:
"Fatal internal error: memory.cpp, line 1038
Labview version 7.1.1"
Thanks in advance
jm
(4,854 Views)
(4,852 Views)
Thank you very much.
I think the proble can be solved in this way, but my problem is that I do not know the library/ies I need to convert. I do not have any info about it in the error message.
jm
(4,842 Views)
Can you elaborate a little bit
(4,831 Views)
Hi again,
what I want to say is that I think I should know the ".dll" files that I have to convert. But my problem is that I do not know which file I have to select to be converted. What I say is I do not have any information related to this in the error message.
Thanks for your help
jm
(4,816 Views)
