saving activex
Hello experts,
I am using WinXP and LV 7.1. I have a VI including ActiveX controls. When I save the VI and install it
on another PC (on which I have installed the ACtiveX), it seems that the VI does not contain any information
about the VI anymore. The container for the
ActiveX is still there, but empty, and I need to right click to re-insert the ActiveX in the container, and re-enter
some parameters. This process is a pain in the neck.
Has anyone encountered that problem, or am I doing something wrong?
Thank you
Phil
(2,978 Views)
I found a problem like yours, in my case was sufficient execute this .reg file on the new computer.
Let me know...
Neona
(2,959 Views)
OK, I've found the problem: The ActiveX control had not been properly registered.
Now it works right away.
Philippe
(2,954 Views)
