saving capture packets in .PCAP format
hello
I am working on acquiring UDP packet from a sensor, I used packet sniffer example in this link: http://www.ni.com/example/27660/en/
the acquiring process works correctly, now I need to save these packets in .PCAP format, on the other hand if I saved packets in .BIN format (binary file) then what should I do to convert this format into .PCAP
(4,273 Views)
Hi! This thread may help you. There is a text2pcap.exe that may help you do it.
https://forums.ni.com/t5/LabVIEW/packet-sniffer-example-how-to-save-as-pcap-files/td-p/873926
Please, let me know if it works for you! Have a nice day!
(4,214 Views)
Does any one found solution for this topic?
(2,050 Views)
Extend the library to allow opening a capture context to a log file instead of a memory session. The principle is pretty trivial as the pcap API provides various functions to open a capture session and the rest remains the same. Of course this requires some C programming knowledge and you need to modify the lvwpcal.cpp file and recompile it into a shared library (DLL) and interface to the new function.
Rolf Kalbermatter  My Blog
(2,037 Views)
ohh! Do you have new library? Is possible to share here?
(2,029 Views)
I'm sorry, the answer is no for both of your questions.
(2,025 Views)
