saving class
original post is here
I use the code " class hierarchy config" posted by tst to set a dog but now i would like to implement save and load dog object from file
i'm a little bit confused on how to do it
any ideas
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,441 Views)
LabVIEW has a shipping example which shows how to write and read an object using a file.
___________________
Try to take over the world!
(3,419 Views)
Accepted by topic author tinnitus
hello tst,
yes i know that, the problem is not the code to save a class
the problem is how to implement?
i don't have the code on this pc and it is to slow the recreate code but i will post an example that shows the problem
regards
Tinnitus
(3,409 Views)
