saving data
Hi
I would like to store the data from an analog waveform, in the form of a excel sheet. i have created a VI for it but when i run it it throws up an error message saying that "it is unable to read, need to increase sample time or real clock error". I am uploading the VI, i would be very much thankful if anyone could help me.
Thank you
rgds
Rajan
(3,335 Views)
Rajan,
What hardware are you using? Are you sure that your hardware is names Dev1 in max?
Amit
(3,317 Views)
You have wired the sample mode to the number of samples per channel in the DAQmx Timing VI. Because of this you have not specified that the sample mode is continuous (it assumes finite by default). Correct it and let us know if that works. Also, I would recommend running a simple DAQmx example so you can be sure that you are able to do DAQ before you attempt File I/O.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,310 Views)
thank you very much
i will try and catch up with u guys....:)
rgds
Rajan
(3,284 Views)
