saving outputs of multiple tabs within the same run into csv file
hello everyone,
I have multiple tabs for a VI that acquires data from daq assistane, in which each tab performs different measurement and plotting functions with some output indicator. So i done this working with stacked sequence structureinside a while loop. Now I want to save all tab outputs with one save report button. However I tried but it is not possible.
Any ideas, thanks in advance.
(2,606 Views)
Stacked sequences are so bad that they are no longer easily available in the latest version of LabVIEW.  Without seeing your code (and don't send us a picture, but attach the actual .vi so we can see everything), we might not understand what you are trying to do, and thus would have a difficult time helping you.
Do get rid of the stacked sequence, however!  If you can't figure out how to do so, post your code and we might make some edits for you ...
Bob Schor
(2,604 Views)
