saving picture
Hi, I have question about the labview program attached in the message. In this program I have three loops and four cases in each loop. I would like to save a picture or pdf every time I'm changing the case. The pdf also attached in the message. Thanks
(3,712 Views)
  • What would you like to save a picture of?
  • It looks like you only have 1 loop, with 3 case structures in it.
  • Attach your code, not a picture of your computer monitor displaying the code.
  • Don't use a double as a case selector (notice the coercion dots)
  • Don't use a "not" on your stop button. You can click the condition so it stops when true instead of continues when true.
  • Use shift registers at the loop inputs and outputs.
  • Merge your error wires together
(3,689 Views)
I attached my program code. the picture i would like to save is attached in the pdf file above. so in each case I would like to save test circuit
(3,677 Views)
I'm still a little confused, you want to generate circuit diagrams using LabVIEW?
(3,673 Views)
Why are there 3 different case structures?  There should only be 1.
Why is there such a mixture of CH0, 1, and 2 a  and Com 0,1,2  they seem to flip places and sometims have Ch2 and Ch2 in different inputs in the same case? (bottom structure case 1)
You've got 3 structures times 5 cases.  The only differences seem to be whether thare are Switch Connect and Switch Disconnect.  And whether you are dealing with the 3 ch's and 3 coms.
(3,648 Views)
I'm trying to do lab interface using test circuits connected to opto 22 and pxi 2567. the test circuits also connected to a relays , so each case will open a circuit and disconnect the others. so what i wanted to do is save a picture for the test circuit I'm working with every time I'm changing the case.
(3,615 Views)
