saving print screen image
Hi all,
I want to save printscreen image into a bmp file, I want to make an installer from this vi to run this application in such a machine which don't have any LV/toolkit/module run time license. But in this case, I don't want to use Vision development kit as it requires run time license and also I don't want to use front panel get image method. I also don't want to use clipboard get image method as it does not work in exe. Is there any other option? Primarily I have used clipboard get image function, I have attached herewith this primary vi. Kindly give me a solution.
(2,953 Views)
(2,936 Views)
