sb RIO chassis temperature
I am working on a system that will include the sb RIO 9602 as the controller.  We want to monitor the temperature inside the enclosure.  The RIO board has a temperature sensor that is referred to as the chassis temperature.  Reading this temperature, it is clearly higher than ambient.  Where is the temperature sensor and what is it measuring the temperature of?
Bruce
(3,417 Views)
Did you convert the value of the FPGA node to get the temperature, like described here?
Christian
(3,414 Views)
Yes, I have done the conversion and believe the reported value.  I'm wondering what exactly is this the temperature of.  Is the sensor in the FPGA, or somewhere else on the board?
Bruce
(3,411 Views)
The temperature is in °C and its the U23 chip at the underside of the sbRIO.
Christian
(3,403 Views)
Accepted by topic author bbarnes
Great, thanks for clearing that up for me!
(3,401 Views)
May I ask why do you mark your answer as solution?
Christian
(3,392 Views)
Sorry, my mistake!  It should have been marked on your reply regarding U23 on the bottom of the board.
(3,382 Views)
